Unsure if related, however engine has been a bit troublesome--stumbling occasionally on take off, more so when cold but still noticeable at times at operating temp. A few days ago check engine light came on, stayed on for 3 days, then went out. Today (day after it went out) I ran the scanner and got a P0466, which posts up as a generic "purge flow sensor circuit range/performance."
I did not clear the code.
Background: I have changed plugs within the last 10,000 miles; air filter changed and within range. Car does have frequent idling for minutes at a time with air conditioner running, lots of short stops. Also run several times a week at freeway speeds averaging 25 mile trips.
Oct 7, 2010 at 4:38 AM
