2004 Kia Optima Fuel Pump
50,000 MILES • 4 CYL • FWD • AUTOMATIC
JEFF PERYSIAN
When you start the car it starts for about 5 seconds the shuts down. We pulled the fuel pump out from the tank and test fired it with 12vdc and it worked
The fuel pump is not getting 12vdc.
Fuse number 1 for the the fuel pump under the hood is good and has 12vdc, replaced the fuel pump relay behind the radio, replaced the cam sensor.
Apr 10, 2010 at 1:30 AM
  • 75,988 POSTS
Check and test the ECM relay behind right side of dash
Apr 10, 2010 at 6:44 AM
