HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Kia
Optima
Ignition
Firing Order
SPONSORED LINKS
Spark plug diagram
OFNARCE
MEMBER
2004 KIA OPTIMA
4 CYL
2WD
AUTOMATIC
Spark plug wiring diagram for a 2.4 Kia optima, 2004.
Monday, February 28th, 2011 AT 12:43 AM
DOCFIXIT
MECHANIC
Here is the engine spark plug firing order. Check out the diagrams (below).
Please let us know if you need anything else to get the problem fixed. Cheers
Images (Click to make bigger)
SPONSORED LINKS
Monday, February 28th, 2011 AT 3:05 PM
BOBGRIFF66
MEMBER
1 POST
2004 KIA OPTIMA
Four cylinder front wheel drive.
I am trying to get the firing order of the engine.
Friday, June 29th, 2018 AT 4:24 PM (Merged)
BLUELIGHTNIN6
MECHANIC
For 1.8L engine :
For 2.0L engine:
For 2.4L engine:
For 2.7L engine:
Hope this helps..
Thanks for using 2carpros.com!
YANNICRISANTOS
MEMBER
2006 KIA OPTIMA
I want to know what is the number four cylinder for that car if you can show a diagram.
SATURNTECH9
MECHANIC
Number four is closest to the transmission number one is closest to the belt.
SPONSORED LINKS
YANNICRISANTOS
MEMBER
Am I pointing at the correct one if not can you point it for me?
Image (Click to make bigger)
SATURNTECH9
MECHANIC
You have a V6. I guessed you had a four cylinder engine. Hold on I will find that information.
SATURNTECH9
MECHANIC
It is the middle cylinder facing the radiator.
YANNICRISANTOS
MEMBER
Thanks.
SATURNTECH9
MECHANIC
You are welcome that is what we are here for.
Please
login
or
register
to post a reply.
Related Firing Order Content
2004 Kia Optima Timing Questions!
Engine Mechanical Problem 2004 Kia Optima 4 Cyl Front Wheel Drive Automatic I Am Replacing The Timing Belt On A 2.4l Kia Optima. I...
Asked by
Usnthem
2004
KIA OPTIMA
Has Been Reprogramed Some 10 Times
My Kia 2004 Ex Optima Has Been Reprogramed Some 10 Times Over The Years With Both The Transmitters And Receiver Replaced. Knowing The...
Asked by
bsn
2004
KIA OPTIMA
Were Is The Sparks Plugs At
Asked by
Anonymous
1 ANSWER
2004
KIA OPTIMA
No Spark
After Much Work, I Believe I Don't Have Spark Because I Fried The Computer When Checking For Spark Coming From My Coil Packs. But, I Got...
Asked by
s1974hall
1 ANSWER
2005
KIA OPTIMA
2005 Kia Optima Timing On A 2005 Kia Optima
2005 Kia Optima 4 Cyl Automatic 80,000 Miles I Had The Timing Belt Changed On My Kia A Few Weeks Back. The Car Was Misfiring...
Asked by
ladytessia
1 ANSWER
2005
KIA OPTIMA
VIEW MORE
SPONSORED LINKS
Misfire Random Code P0300
Spark Plug Replacement Ford Escape V6 3.0L
Spark Plug Replacement - Chevrolet
Online car repair manuals
