2004 Kia Optima cam sensor
96,000 MILES • 4 CYL • FWD • AUTOMATIC
JWILSON14
I replaced the timing belt and pulleys also crank sensor. reassembled then drove car stalled shortly afetr and has a code for "cam sensor problem". What could be possible problem
Mar 3, 2010 at 4:03 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check to make sure didnt accidentally disconnect cam sensor, if OK may need to test cam sensor to ensure it doesn't need replaced also.
Apr 30, 2010 at 2:44 PM
