How do you reset the airbag warning light on a 2004 kia optima
Aug 24, 2008 at 3:59 PM
✓Experienced Mechanic
Hi there,
If the warning light is active and the fault has not been repaired you are unable to re set the light, (it will re set with the next self test,) that is when you turn on the ignition, have the code inspected and repaired, the SRS system will be in-op until the faults repaired.
Mark (mhpautos)
Aug 24, 2008 at 4:16 PM
