2004 Kia Optima
85,448 MILES • 4 CYL • FWD • AUTOMATIC
VEL0909
i was at a stop light and when i stared to go my car stop running, so i change the battery coil cables and sparkplugs and the camsensor and still won't star.
Sep 22, 2010 at 11:23 AM
  • 75,988 POSTS
Pick your symptoms:
**Cranks but no start condition:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada when key is engage to starting position
Could be the starter, starter relay,park and neutral switch/transmission position switch and ignition switch assuming the battery and connections are good. Note:If it doesn't apply disregard.
Sep 23, 2010 at 10:20 PM
