2003 Kia Optima passenger door wont unlock
60,000 MILES • 6 CYL • FWD • AUTOMATIC
ROSSTIM68
the passenger front door will not open when the door is unlocked. how can i remove the panel to check the door lock
Sep 14, 2008 at 4:45 AM
  • 110,248 POSTS
There are a few screws that need removed, the arm rest and window crank. Then there are clips between the panel and the door that will unclip when you remove the panel.
Jul 11, 2009 at 3:26 PM
HIT2HIT
first lock ur doors,try disconnecting the battery,use ur car keys 2 open the door .see if that works 4 u .if that dont work.connect the battery. try unlocking ur doors. now disconnect the battery,again use ur keys .hope that works.
Dec 19, 2010 at 12:06 AM
