2003 Kia Optima Died While running
ROGER40
Engine Mechanical problem
2003 Kia Optima 4 cyl Two Wheel Drive Automatic
The car died after running I know the battery is bad it was 5 year's old bad cell. but after replaceing the battery it still will not start. working on car's my past expierince tells me this is an alternator or it could be the starter possibly. but will a car die if the cylonoid is going bad on the starter? and is another way I can find out which if either it is?
Thank You
Roger Doss
Feb 17, 2009 at 5:57 AM
DAVE H
  • 13,383 POSTS
jump start the vehicle .. put a voltmeter across battery terminals .. you should get a reading of around 13.5 volts @ idle .. if you are getting less than 13 volts check wiring to alternator or replace the alternator !!
Feb 19, 2009 at 10:47 AM
