2003 Kia Optima Belt
10,000 MILES • 4 CYL • FWD • AUTOMATIC
BIGBOIBO05
How do you change the powersteering belt
Nov 8, 2009 at 6:52 AM
DAVE H
  • 13,383 POSTS
Power Steering & A/C Compressor Loosen tension pulley adjustment bolt "A". See Fig. 5 . NOTE:Belt tension must be measured between the specified pulleys. See deflection measuring positions in Fig. 1 . Turn adjusting bolt "B" to set belt tension to specified deflection. See BELT ADJUSTMENT table. Tighten tension pulley adjustment bolt "A" to specification. See TORQUE SPECIFICATIONS . Recheck belt deflection after cranking engine over one or more revolutions and readjust as necessary. NOTE:When a new belt is installed, adjust the tension to the central value of the standard range indicated for new belt deflection. Let the engine idle for 5 minutes or more, and check the standard value indicated for inspection. Readjust belt tension as necessary. When adjusting a belt which has been used or a belt newly installed after 5 minutes or more of operation, refer to the standard value indicated for used belt deflection. See BELT ADJUSTMENT table.
https://images.2carpros.com/forum/automotive_pictures/266999_kia_39.jpg
Nov 8, 2009 at 10:51 AM
