While driving, occassinally the transmission will like shift to low gear and the check engine lite will come on. After shutting the motor off, then starting it back up, the check engine lite goes out and the transmission shifts ok. What would cause this and what can I do to fix this?
SPONSORED LINKS
Monday, June 7th, 2010 AT 2:39 PM
