I stick the key in the ignition and a ticking starts. Then we I turn the key, the lights dim and the car won't start. Any information would be great. Thank you so much
Thursday, December 11th, 2008 AT 7:29 AM
MECHANIC
The car won't start.-Does it crank and refuses to start or just won't crank at all/nothing?
Test the battery condition and its connections -then comeback
SPONSORED LINKS
Thursday, December 11th, 2008 AT 7:45 AM
TRACYFIG2
MEMBER
It won't start at all, nothing happens. I checked the the battery. There is a little corrosion on the terminals. Other than that everything is connected tight.
Thursday, December 11th, 2008 AT 7:52 AM
MECHANIC
Test the battery we need to take it out of the picture before we go somewhere else-
