2001 Kia Optima Clutch
26,000 MILES • 4 CYL • FWD • MANUAL
57JED
Hello, I have a 2001 Kia Optima that has a problem with the clutch. I can go all the way to the floor with no resistance and can not shift the car while running. I need help
Thanks, Jack
Jun 29, 2010 at 12:47 PM
BLUELIGHTNIN6
  • 16,542 POSTS
first check the clutch fluid level. if it is low then check for leaks and refill. if it is fine then the clutch disc is probably worn and needing replaced
Jun 29, 2010 at 11:16 PM
