2001 Kia Optima Brakes
CANDACEK12
Brakes problem
2001 Kia Optima 6 cyl 10012 miles
Kia Optima 2001 V6. I recently got my front bakes and rotors repaired. Whenever I drive the car now, it jerks everytime I stop. And sometimes I can hear the car making a grinding noise when I press the brake. The company who repaired the brakes said I may need new tires but a second opinion said the tires are fine and the brakes need to be repaired. What can I do to repair the problem?
Oct 5, 2009 at 5:20 PM
  • 110,248 POSTS
It doesn't sound like a tire problem. Has anyone actually checked the brakes to see if something has happened? I have seen the brake pads fall apart in the past. If you are getting a grinding, that may have happened, or the pads themself may not have been properly installed.
Can you give me a better description of the noise and problems you are having?
Oct 12, 2009 at 12:52 AM
