2002 Kia Magentis Alternator
2002 KIA MAGENTIS
DAVEBOY
Electrical problem
2002 Kia Magentis 4 cyl Front Wheel Drive Automatic
Can you please explain how to remove the alternator
on a Kia Magentis 2002? I am able to remove the bolts
but I can't release the tension on the belt, there is a separate belt running of the crankshaft, not the timing belt. Can you post an exploded view as well?
Thanks
Oct 23, 2010 at 8:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
loosen the adjusting bolt
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_752.jpg
Oct 23, 2010 at 3:09 PM
DAVEBOY
Is that the pulley with 4 small bolts around it, it looks like it could be a cover? Also does the second wire have a nut on it, it is on the opposite side and not easy to get to from the top?
Oct 24, 2010 at 1:58 AM
DAVEBOY
Is this arm supposed to move freely when the
adjusting screw is loosened? Mine doesn't budge.
Which way loosens the belt up or down?
Oct 24, 2010 at 7:22 AM
BLUELIGHTNIN6
  • 16,542 POSTS
rotate left to loosen, right to tighten
Oct 24, 2010 at 10:47 AM
