2001 Kia Carens thermostat
2NARRAS
2001 Kia Carens
I am trying to change my thermostat in my carnival. I have taken half the engine out to get to it. Some sites have said it is on the side. My one I think is below the manifolds and has a plastic cover. I ac get to it now since I have stripped the motor. It has two bolts and a plastic shaft that leads to the water pump. It does'nt seem to want to come off is it glued in or am I missing something.
Many Thanks
Pulliing my hair out
May 15, 2010 at 4:02 PM
BLUELIGHTNIN6
  • 16,542 POSTS
did the motor recently overheat? if so then the thermostat gasket probably melted and sealed the two surfaces together. will just have to take a flat blade tool and pry it apart.
May 16, 2010 at 4:44 AM
