coolant leak
170,000 MILES • 3.6L • 6 CYL • FWD • AUTOMATIC
ACHEESEHEAD
It is leaking on the driver side where next to and below the air cleaner. Hard to see exactly where, but the radiator hose goes into some kind of unit in that location. The hose is dry.
Mar 13, 2017 at 6:45 AM
  • 55,709 POSTS
It sounds like the upper radiator hose is leak at the thermostat housing, here is a guide hat will help you locate the leak and get it fixed
https://www.2carpros.com/articles/car-is-leaking-coolant
and
https://www.2carpros.com/articles/coolant-leak-symptoms
Please run this test and get back to us so we can continue helping you.
Best, Ken
Mar 16, 2017 at 4:42 AM
