Drive belts
LAMM90
  • 5 POSTS
How do I release the tension to change the belts?
Jul 2, 2009 at 6:10 AM
DAVE H
  • 13,383 POSTS
BELT ADJUSTMENT Power Steering Loosen hinge bolt "A" and flange nut "B". See Fig. 4 . Turn adjusting bolt "C" to set belt tension . See Fig. 4 and Fig. 5 . Tighten hinge bolt "A" and flange nut "B" to specification. Alternator & Air Conditioning Compressor Loosen pulley lock nut "A". See Fig. 6 . Turn adjustment bolt "B" to set belt tension . See Fig. 6 and Fig. 7 . See BELT ADJUSTMENT table. Tighten pulley lock nut "A" to specification. Start engine and turn A/C on. Allow vehicle to run until normal operating temperature is reached. Turn engine off, recheck belt deflection after operation and readjust belt tension as necessary.
https://images.2carpros.com/forum/automotive_pictures/266999_kia_38.jpg
https://images.2carpros.com/forum/automotive_pictures/266999_kia2_1.jpg
Nov 8, 2009 at 10:34 AM
2CP-ARCHIVES
  • 4,540 POSTS
how to replace power steering belt
May 10, 2019 at 11:34 AM (Merged)
KHLOW2008
  • 41,812 POSTS
P
ower Steering
1. Loosen hinge bolt "A" and flange nut "B". See Fig. 4 .
2. Loosen adjusting bolt "C" until you are able to get belt off.
3. Install new belt. After belt is seated, pull it to slide around pullies to ensure it is seated correctly.
4. Turn adjusting bolt "C" to set belt tension to specified deflection.
5. Tighten hinge bolt "A" and flange nut "B" to specification.
CH311
need a serpentine belt diagram for a 2005 kia amanti
DAVE H
  • 13,383 POSTS
https://images.2carpros.com/forum/automotive_pictures/266999_am_2.jpg
RICK MAHAN
Serpentine broke, need to replace but it seems too long following diagram.
WRENCHTECH
  • 20,760 POSTS
Here is the diagram.
RICK MAHAN
Thank you so very much. It worked. Your help is very much appreciated.
WRENCHTECH
  • 20,760 POSTS
You are welcome.
