Computer swap
100,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
LIVEFREE1973
Does anyone know the answer to this question. Will the computer from a 2003 Kia Rio work in the car listed above?
Apr 3, 2017 at 2:54 AM
HMAC300
  • 48,601 POSTS
I would not try it as they need to be reprogrammed by a mechanic otherwise car will not start no matter what an auto parts tell you. they can be rebuilt. why do you need a PCM?
Apr 3, 2017 at 3:14 AM
STEVE W.
  • 15,409 POSTS
Entirely different units. The 22003 Optima is actually a Hyundai Sonata with different trim while the Rio was a Kia design in 2003. In reality you could not even take two identically optioned 2003 Kia Rios and swap the computers. The internal security software would simply prevent both cars from starting.
Apr 3, 2017 at 5:15 AM
LIVEFREE1973
Thank you guys for your responses to my question I put OBD2 tester on it and it will not even read anything.
Apr 3, 2017 at 6:03 AM
STEVE W.
  • 15,409 POSTS
Check to see if you have power to the OBDII port first, no power and the reader will not connect. There is also the possibility that your reader will not talk to that particular make/model, even if it says it will.
Try a different tool.
What is the problem with the car at the moment?
Apr 3, 2017 at 6:36 AM
