keys locked inside
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
HEATHER CUMMINGS BECK
Started vehicle and had to go inside house for a second. Doors locked with keys in ignition and car still running. Now I cannot get inside of vehicle? Help!
Apr 23, 2018 at 3:44 PM
KHLOW2008
  • 41,812 POSTS
You need the help of a locksmith or mechanic to help you open the door. Meanwhile you can try using a key that fits into the key hole and try wiggling to unlock. There is a possibility the key cylinders might accept other than the original key to be turned.
Good luck.
Apr 23, 2018 at 6:59 PM
