keys locked inside
1998 MITSUBISHI MONTERO
130,000 MILES • 6 CYL • 4WD • AUTOMATIC
HEATHER CUMMINGS BECK
Started vehicle and had to go inside house for a second. Doors locked with keys in ignition and car still running. Now I cannot get inside of vehicle? Help!
Apr 23, 2018 at 10:44 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
You need the help of a locksmith or mechanic to help you open the door. Meanwhile you can try using a key that fits into the key hole and try wiggling to unlock. There is a possibility the key cylinders might accept other than the original key to be turned.
Good luck.
Apr 24, 2018 at 1:59 AM
