Key-less remote entry
145,865 MILES • 3.6L • 2WD • AUTOMATIC
GRANDMA CONNIE
Have key-less remote and gets stuck in ACC, key doesn’t come out. I have to leave it in anywhere from 15-45 minutes for it to release. Doesn’t do it all the time. Any suggestions?
Aug 4, 2019 at 11:27 AM
  • 55,710 POSTS
This sounds like the shift cable is worn not putting the transmission all the way into park which will not release the key but to make sure when the key is stuck go under the hood and push the gear selector arm one way and then the other to see if it moves and if so does the key come out?
This video is something slightly different but it shows the arm I want you to try and move:
https://youtu.be/UtMsbNzquCk
Aug 6, 2019 at 4:21 AM
