Key-less entry
150,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
BIGJWEEZY
Sometimes will not unlock and have to use key. Sometimes i cannot even use lock on door until key is in ignition. Same goes with trunk. When it does manage to unlock with key-less entry, it will only unlock drivers door. Also, randomly tries to lock while driving at any speed.
Mar 10, 2017 at 8:19 PM
HMAC300
  • 48,601 POSTS
check battery in key fob first and auto parts can check if key fob is working. then have a mechanic scan the system for codes it may be a control unit inside car or relays messing up causing the constant unlocking .
Mar 10, 2017 at 10:38 PM
