Key-less access
70,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
DZMITRY
  • 11 POSTS
Help! I am from Belarus. Please help. 1500 truck, with key-less access.which one can replace, what frequency 315 MHz or 433MHz?
Jan 5, 2018 at 3:10 PM
SATURNTECH9
  • 30,869 POSTS
You are going to have to go by the number on the back of the remote. What happened did the remote just stop working? You have the old remote correct?
Jan 5, 2018 at 3:29 PM
DZMITRY
  • 11 POSTS
Remote funtion actuation module GM 09387160 Canada 218 101 368A model/fcc AB01502R
Jan 7, 2018 at 1:21 PM
SATURNTECH9
  • 30,869 POSTS
Have you checked the battery Yet? Also, you can clean them and re-synced the remotes.
Jan 7, 2018 at 1:44 PM
DZMITRY
  • 11 POSTS
How can i clean?
Jan 7, 2018 at 5:39 PM
DZMITRY
  • 11 POSTS
How to disable the security feature?
Jan 7, 2018 at 8:43 PM
SATURNTECH9
  • 30,869 POSTS
It's in the body control module and we don't give out that kind of information.As far as cleaning the remote you open the remote with a coin.Then remove the circuit board and you will see where the buttons meet the board black stuff built up on the board.You can use a tissue to clean the board and button as well.When you stop getting black stuff in the tissue it's clean.Also test the battery it should have over 3 volts in the battery if it doesn't replace the battery.When all that's done see if the remote works.if not bring the remote over by the car and hold the lock and unlock buttons down about 30 seconds see if it honks lights flash power door locks operate etc.If that happens see if the remote now works.
Jan 9, 2018 at 12:46 AM
DZMITRY
  • 11 POSTS
my remote does not work, the battery is 3 volts, it's clean. what remote controller to replace?
Jan 29, 2018 at 8:28 PM
DZMITRY
  • 11 POSTS
my GMC is not to be picked up in damp weather, but I want to continue, when it's dry or cold, all is well. Gasoline comes in, the pressure is there, the spark on the spark plugs is good. What can be?
Jan 29, 2018 at 8:59 PM
SATURNTECH9
  • 30,869 POSTS
So is the security light on solid or flashing with the key in the run position?
Jan 30, 2018 at 11:46 AM
DZMITRY
  • 11 POSTS
The securety light flashing
after a time turns off
Jan 30, 2018 at 3:17 PM
DZMITRY
  • 11 POSTS
The smoke from the pipe is there, but the engine does not work
Jan 30, 2018 at 3:24 PM
SATURNTECH9
  • 30,869 POSTS
Give what I posted posted a try and let me know what happens.
Jan 31, 2018 at 12:11 AM
DZMITRY
  • 11 POSTS
Thank you very much, the engine is running, the problem was in the passlock, there was one problem with the keyfob, you need a new one, how can I replace it?
Feb 3, 2018 at 12:18 AM
SATURNTECH9
  • 30,869 POSTS
How do you know the key fob is bad ?Did you test the battery in the fob?Also they have testers that can see if the key fob is sending a signal out.You would need a high end professional scan tool to program the new key fob to car.You most likely have a problem in the pass lock system and that was a temporary solution.You would have to get the body control module scanned for codes.That would be a high end scan tool to do trhat as well.Then let me know the exact code numbers not code descriptions not all the professional scan tools will be able to program your key fob to the car.
Feb 3, 2018 at 12:59 AM
DZMITRY
  • 11 POSTS
The battery in the keychain is new, the oscilloscope showed no signal on the antenna keychain. Remote funtion actuation module GM 09387160 Canada 218 101 368A model/fcc AB01502R
Feb 3, 2018 at 10:32 PM
SATURNTECH9
  • 30,869 POSTS
Sounds like you covered all your bases and need a new key fob.Rockauto dot c9m sells them I would post the link but from there online catalog that never works.I have a 5 percent discount code if your interested.Ypu will still need a capable scan tool to program the new remote.
Feb 4, 2018 at 5:48 AM
