Key will not turn to off position
151,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
BOBBI JO
My key will turn the engine off but it will not go back to the off position. So I have to take a battery cable off when I am somewhere too long so I do not drain my battery.
Feb 17, 2018 at 10:46 PM
CJ MEDEVAC
  • 11,000 POSTS
See if tilting the column to different positions helps to make the key move.
Until you get it right, one of these could really be your buddy.
Picture below is for a "Top Post" battery, you can also get one for a "Side Post" battery at an auto parts store.
I have a similar set up on my Jeep, Mine is there so that I can drain the battery to work on it. But mostly for in the event (it rarely happens) that my solenoid hangs up (and the starter cranks endlessly/ wires overheat/ etc.) I can quickly drain the battery with no tools needed.
Keep us posted,
The Medic
Feb 18, 2018 at 12:11 PM
