I put it in the ignition the key does not turn
21,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
MIKE730
i changed the battery in my car. i didn't drive it for 7 days. I went to drive the car today and when i put the key in the ignition the key did not turn. I thought something was wrong with the chip so I went to dealership and had them cut me another key. The new key opens the door to the car but when I put it in the ignition the key does not turn.
Oct 29, 2019 at 11:37 AM
Sounds like the ignition switch is just stuck. Here is a guide that will help with this. I would start with lubricating it as shown and then replace it if this doesn't work.
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Below is the process on how to replace the cylinder if this does not work.
Let us know if you have questions. Thanks
Mar 12, 2021 at 10:33 PM
ITAFREAKINFORD
  • 19 POSTS
Or sometimes when. You park the steering wheel goes to a weird position grab the wheel see if there is tension if so hold it at that point turn the key see if it turns it usually will unless really broken if so see above they give good advice and so a food job here
Jul 20, 2023 at 12:42 PM
