Key will not turn?
15,000 MILES
DAVID BEAVER
The key won't turn and the brakes when you push them no pressure, I'm broke down at a gas station.
Oct 24, 2023 at 7:04 AM
  • 110,248 POSTS
When you press the brake pedal, does it go to the floor? Also, was there any indication of a problem starting when it comes to the ignition key? I'm struggling to see how they could be related.
Let me know. Also, I suspect the key is locked in the off position. However, let me know if anything electrical is working. For example, are the headlamps working?
Take a look through this link and let me know if anything helps:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Oct 24, 2023 at 10:44 AM
