Key will not come out of the ignition
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
MEATYMCMEATMISSILE
Like the title says. it is stuck. It is in park and will start, but wont release the key. I tried the ignition at first. And when i disconnected the battery the key came out. so i knew it has to do with the gear shifter. linkage is fine i think. Is it the the shift interlock solenoid?
Jul 15, 2019 at 5:51 AM
  • 55,673 POSTS
This can happen when the shift cable goes bad and does push the transmission completely into park. Can you go to the transmission level and try to push it further into park? Please let me know.
Jul 17, 2019 at 6:09 AM
Hi. Yes. There is a contact in the shifter called the interlock and it is responsible for telling the ignition that the vehicle is in park and it is safe to remove the key. When this begins to stick it no longer sends that info and the ignition thinks the vehicle is still in gear.
If you look at the attached document this will explain in more detail. You have two portions of this. One to tell the shifter your foot is on the brake and it releases the shifter. The second (your issue most likely) is the Key Interlock.
I also attached the testing for this solenoid. Let me know if you have questions. Thanks
Jul 17, 2019 at 7:02 AM
