Key will not turn on fuel pump anti theft code or switch is failing turn over no start?
250,000 MILES • 2.4L • MANUAL
ROGER_1
Key won't turn on truck anti theft possible how to disable anti theft do ylyhey use codes or does 2000 toy have a protocol they use
Oct 7, 2026 at 7:48 PM
  • 55,837 POSTS
Can I ask if the truck had an aftermarket alarm? Also can you please upload a short video of the issue so I can se what it going on? The fuel pump normally receives power when the engine is cranking or running. Simply turning the ignition key to ON may not activate the pump. The engine computer uses starter and engine speed signals to control the circuit opening relay, which supplies power to the fuel pump. Please go over this video, can may help us.
https://www.youtube.com/watch?v=lXLJbuAZ4CE
Oct 9, 2026 at 4:11 PM
