Key switch
125,000 MILES • 4.3L • 6 CYL • RWD • AUTOMATIC
TINA LOWE
Key switch will not lock in order to shut car off and gear shifter will engage without pressing in shift release button.
Mar 6, 2017 at 2:45 AM
  • 55,740 POSTS
Hi Tina,
It sounds like the ignition tumber/lock is worn out which is a common problem. Yo fix the problem the tumbler must be replaced also you will need to get it from the dealer so they can re-code the key for you so the security will work correctly.
There is an outside chance the shifter cable is coming apart down at the transmission or where it plugs into the steering column. Check both ends while trying to shift it to see if they move at all.
Best, Ken
Mar 8, 2017 at 6:58 AM
