Key stuck in the ignition
234,000 MILES • 1.6L • 4 CYL • 4WD • AUTOMATIC
KHADIJAH ID BRADFORD
My key is forever stuck in accessory mode. The only way the key will come out is if the battery is completely drained. I do not have he funds to get the key ignition fixed right now. I was wonder where the fuel pump fuse is located so I can unplug it and undo the negative battery side.
Jul 8, 2017 at 8:20 AM
  • 55,766 POSTS
Yes it would be okay to just take off the negative battery cable,
Here is a guide that can help
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Here are some guides if you want to replace the ignition switch
Cheers, Ken
Jul 10, 2017 at 6:53 AM
