key stuck in ignition?
20,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
RON.WINKLER
i was going to see if my truck would start after several years of not being used, so i found my key and placed it in the ignition and turned the key. My truck did not start because of the battery; but my key will not come out. I googled helps and tricks to get the key out those did not work and i also looked at the owner's manual and it said something about the anti-theft lock.
Aug 19, 2022 at 10:10 AM
  • 110,251 POSTS
The anti-theft won't prevent you from removing the key. It can prevent the engine from running, but I suspect it has to do with a dead battery. By chance, have you tried charging the battery to see if it will then turn?
Aug 19, 2022 at 4:18 PM
