Key stuck in ignition
106,500 MILES • AUTOMATIC
SUNEEL.BANDARUPALLI
Key stuck in ignition between O and I. I could not turn nor pull it out. Shift is in "park" level.
Oct 2, 2017 at 4:02 AM
  • 55,604 POSTS
Try to cycle the key and move the transmission in and out of gear to see if that works if not then what happens is the ignition key lock tumbler ends up falling apart and it needs to be replaced.
Here are some diagrams (below) that will show you what you are in for when doing the job:
Please let us know what happens and upload pictures or videos of the problem.
Cheers, Ken
Oct 3, 2017 at 4:39 AM
