Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Vandura
Electrical
Ignition Switch
Key
Stuck
Key stuck in ignition
1993 GMC VANDURA
93,000 MILES
TIM TOWNSEND2
MEMBER
1 POST
My key is stuck in the on position, it will not turn back and key will not come out.
Jun 28, 2017 at 10:21 PM
SATURNTECH9
Experienced Mechanic
Here is how to remove your ignition cylinder most likely you have a bad ignition cylinder.
Images (Click to enlarge)
Jun 29, 2017 at 5:51 AM
SATURNTECH9
I just had a 1993 Chevrolet truck doing the same thing removed the ignition cylinder and found it was all bound up.
Jun 29, 2017 at 6:03 AM
Add image or video
Ask a new question
