Key stuck in ignition
129,000 MILES • 2.4L • 6 CYL
TAMMYE BRANTLEY
  • 11 POSTS
The engine has been replaced. The key has worked several days. I got in it Friday, put the key in, engine would not turn over. It did nothing, the gauges did not come on. Then I could not get the key out. Any suggestions on how to key out ?
Feb 22, 2020 at 11:06 PM
Good morning,
The battery is dead. You need to charge the battery. Once power gets back into the system, the key will release.
https://www.2carpros.com/articles/how-to-charge-your-car-battery
You need to have the battery load tested and the charging system tested to be sure the alternator is working.
Feb 22, 2020 at 11:31 PM
