Key stuck in the ignition in the on position
145,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
JENN309
It turns to the start and run positions. It just wont turn back to the lock position to release the key. I don't see anything visibly wrong with the shifter. Help
Sep 6, 2019 at 12:01 PM
94 TRANSAM
  • 680 POSTS
Hi Jen, Welcome to 2CarPros. Lets see if we can help you out.
There are generally 2 reasons you cant turn the key back to the lock position.
1: You have and issue with your shifter that is preventing it from locking into park. It could be bent or just worn out.
2: The key cylinder has fallen apart internally and the tumblers are hung up stopping it from going.
The easier and cheaper of the 2 would be to replace the key cylinder. Here is a guide to help with that and it also has a few things you can try to get it unstuck:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Let us know if this helps.
Rich.
Sep 8, 2019 at 10:36 AM
