key will not turn completely off
87,000 MILES
ROSALIND WATKINS2
Changed the ignition switch still have the problem which I've narrowed to the gear shifter. when I remove the shift knob the yellow stick does not pop all the way up to release the key. why is this? What is the fix?
Mar 9, 2021 at 12:02 AM
This is called the shift interlock. I attached the info below on how to replace the solenoid.
Here is a guide that will help give more detail on this:
https://www.2carpros.com/articles/ignition-switch-wont-turn-stuck
Let's run through this material and let us know if you have questions. Thanks
Mar 10, 2021 at 2:10 AM
