The first thing I need you to check is the ignition fuse under the hood. It is in the power distribution box. I had a truck last week that did the same thing. Actually, we could not remove the key or take it out of park.
I have attached a picture of the fuse layout. Picture 2 is of the amperage fuse required. These are not the tiny fuses. Look for Ignition fuse A and B. Both are 40 amp fuses. See attached pictures.
Let me know if this helps.
Images (Click to enlarge)
Jul 8, 2018 at 2:38 PM
