Key Relearn I went through the whole process still not working?
177,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
AMYLOU36
I replaced the ECM and was given instructions on how to do the key relearn. The key was already stuck in the ignition so after the new ECM was installed, I turned the key to the on position and waited the 10 minutes for the light to go off, but the light never went off. I waited for about 20 minutes and nothing happened, so I turned the key to off and waited 5 seconds and turned it back to the on position and again the light didn't go off. I went through the whole process but the relearn didn't work. Now the fuel pump doesn't come on when I turn the key. I thought it could've been the battery at first but now I don't know what it is. Is there a way to start over? Or does anyone know how I can fix this?
Dec 29, 2024 at 11:04 AM
  • 55,616 POSTS
I would make sure the remote has a new battery, also can I ask if the ECM has pre-programmed? If not, this will be the problem. Once the ECM is ready this is how to relearn the keys in the images below. You can get a preprogrammed unit by searching Google or Ebay. Check out the images (below). Please let us know what happens.
Dec 30, 2024 at 3:05 AM
AMYLOU36
Yes, the unit was programmed to my VIN.
Dec 30, 2024 at 5:34 AM
  • 55,616 POSTS
Okay, I would use the key relearn procedure in the images above. Let me know how it goes.
Dec 31, 2024 at 3:22 AM
