Key not detected?
AUTOMATIC
VEEE
I lost my secondary key and trying to connect my car to the first I had I started using my secondary key because my first key battery fired but any way I got a new battery the locksmith said the key was working but he did try to communicate with the car through a obd and the car want communicating but it still is saying no key detected my car battery got checked that’s fine idk what to do. All the fuses are okay. I tried the hard reset it just saying no key detected with a car with a lock in it.
Oct 7, 2026 at 3:19 PM
  • 55,781 POSTS
Sit inside the vehicle with the transmission in Park and your foot on the brake. Hold the smart key directly against the Engine Start/Stop button and press the button using the key itself. Hyundai provides this procedure for situations where the smart key battery is weak or the key isn't being detected normally. Make sure the new remote battery is the correct type, installed with the proper polarity, and making good contact with the terminals.
Before replacing any parts, I have three questions:
1. When you press the Start/Stop button with the smart key directly against it, does the engine start, crank, or do nothing?
2. Do the lock and unlock buttons on your remaining key operate the door locks?
3. When the locksmith connected the scanner, would it power on but fail to communicate, or did the scanner not power on at all?
These answers will help us narrow this down to a key recognition problem, an immobilizer malfunction, or a vehicle communication issue.
Let me know what you find, and we can go from there.
Oct 9, 2026 at 4:06 PM
