Key not coming out of ignition lock
2013 SUZUKI
12 MILES • 1.2L • 4 CYL • FWD • AUTOMATIC
AMITANSHU
Sir,
My maruti Suzuki Ritz automatic is creating issues from last one month.. After driving car when it is parked key does not come out of ignition no matter of any technique applied.. Even tried with new key.. Howvever next day after starting car again and then after moving wheels it easily comes out.. This problem had started after rear break shoes of car were changed at service center.. Car till datr ran for 23000 Kms.. Electrical lube already tried.. What may be the reasons and any risk associated? Also can the gps device tracker attached to immobolizer be responsible for it as only during last month my GPS device SIM got deactivated..
Aug 22, 2016 at 4:45 AM
  • 31,937 POSTS
The problem will not be related to the brake repair, the problem may be a worn ignition lock, if you have a lot of keys on the key ring it will eventually wear out the lock with all the weight swinging off the key barrel, look at this first.
Aug 22, 2016 at 10:25 AM
AMITANSHU
Nothing attached with key, not even key chain.. What may be the solution fot it?
Aug 22, 2016 at 5:35 PM
  • 31,937 POSTS
I would still be considering that the barrel and key is at fault try powered graphite ad a lube of the key is stuck the blades in the barrel are jamming
Aug 22, 2016 at 5:42 PM
