Key is stuck in the ignition.
130,000 MILES • 4.6L • V8 • RWD • AUTOMATIC
IOWACHIEF
Key is stuck in the ignition .I have removed the ignition cylinder lock, taken the key out and sprayed powdered graphite in it. This had no effect. I have replaced the ignition cylinder lock. No effect. The key starts the car and works in all positions, I just can't remove it.
Jan 11, 2015 at 9:17 AM
WRENCHTECH
  • 20,760 POSTS
It is likely the Park lock out causing that. The shifter has to be all the way in Park before it will turn all the way to lock. The linkage for that could be worn out of loose preventing it from locking.
Jan 11, 2015 at 6:24 PM
ZOLATOY
  • 18 POSTS
GOOD ANSWER ....I GUESS THAT'S WHY YOU GUYS ARE THE PROS.....,
Oct 2, 2016 at 10:58 AM
