key gets stuck in ignition after new battery installed
123,000 MILES • 4.6L • V6 • 2WD • AUTOMATIC
FABMOM57
About a month ago, my key was getting stuck in the ignition. it is now happening everyday. i thought it was the cylinder and ordered one from a Cadillac parts place. Called a locksmith, he said the key and cylinder are fine, showed me how to release the key manually using a screw driver. Said it was a sensor. Called Cadillac maintenance company, they said the battery is bad and there is not a sensor in the steering wheel. Had the battery check, and purchased new battery today. Key was stuck in ignition, had to use a screw driver to remove it. Help!
Aug 4, 2016 at 3:45 AM
RIVERMIKERAT
  • 6,106 POSTS
Sounds to me like the locksmith does not like working on cars. A key getting stuck in the ignition switch and then being able to be released using a screwdriver is a faulty ignition switch, not a sensor.
Aug 4, 2016 at 3:48 AM
FABMOM57
thank you, I feel much better knowing this is the problem.
Aug 4, 2016 at 4:33 AM
RIVERMIKERAT
  • 6,106 POSTS
My pleasure. Happy to help. Tell your friends about us.
Aug 4, 2016 at 5:13 AM
