key fobs and keyless entry
160,000 MILES • 4.2L • 6 CYL • AUTOMATIC
MARCIA ANN PETMAN
My two key-fobs and key-less entry pad quit working within two weeks of each other. The batteries in the key-fobs are good. The key-less entry pad lights up but will not open the door with the correct code. Could this be a fuse issue with the entry pad?
Oct 18, 2017 at 12:42 PM
  • 31,937 POSTS
Probably a faulty fob, or a issue with the program. you can try getting both fobs reprogrammed and start here. i have see fobs lose program for no reason. Ford needs both fobs together to do a fob re-flash, try this first.
Oct 18, 2017 at 3:04 PM
