After replacing the key fob battery it does not work?
211,000 MILES • V8 • 4WD • AUTOMATIC
DRANMA
  • 6 POSTS
I replaced the battery in the key fob and now it won't work, does it need to be reprogrammed?
Apr 5, 2024 at 2:23 AM
  • 110,248 POSTS
Replacing it shouldn't require reprogramming. Are you sure you have the battery positive facing the right direction in the FOB?
As far as programming, here is a link that explains how to do it:
https://www.2carpros.com/articles/how-to-re-program-a-key-remote-fob
Let me know if that helps.
Apr 5, 2024 at 1:29 PM
