Key fob
180,000 MILES • 2.4L • 6 CYL • TURBO • FWD • MANUAL
JORDAN VAN BUSKIRK
Car battery died after six months and now the key fob needs to be replaced is there anyway i can do this myself?
Mar 8, 2017 at 12:38 PM
HMAC300
  • 48,601 POSTS
If you have another one you can program it yourself, but check battery auto parts can check it as well as see if it still works or not.
Mar 8, 2017 at 9:53 PM
JORDAN VAN BUSKIRK
I only have one fob and the dash is saying key not detected.
Mar 9, 2017 at 12:27 AM
HMAC300
  • 48,601 POSTS
then it is the key not the fob. you will have to have a mechanic or locksmith program a key for you then the anti theft is keeping you from stating car not the key fob.
Mar 9, 2017 at 1:30 AM
JORDAN VAN BUSKIRK
Any places I could go to near me? I live in west bend WI? And estimate on price?
Mar 9, 2017 at 1:32 AM
HMAC300
  • 48,601 POSTS
you will have to check locally we are not near Wisconsin.
Mar 9, 2017 at 4:09 AM
STEVE W.
  • 15,377 POSTS
The problem could be a bad key or bad key reading sensor or even a simple broken wire. The problem is to determine which it is. The dealer would likely be the fastest fix (probably not the cheapest though) as they can scan the system and see where the problem is, and be able to get the proper parts faster.
Mar 9, 2017 at 11:45 AM
