After disconnecting the battery my key fob is not working, and my tire light is on.
Jun 14, 2025 at 11:55 PM
✓Experienced Mechanic
So what sometimes happens is the connection at the battery can cause a voltage surge which can distract the protocol for the CAN bus system. I would do a hard system reboot to restart the systems from scratch. This guide can show you how:
Image (Click to enlarge)
Jun 16, 2025 at 11:46 PM
JOHNSK62
MEMBER
Both fuses are good...
Jun 18, 2025 at 11:13 AM
Okay, then it looks like the TPMS and keyless entry control module is out, here is the location so you can check it out. A CAN scan should help confirm it. It looks like it will need to be programmed in. Check out the images (below). Please let us know what happens.
