Key fob does not unlock/lock after car was in an accident
85,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
TAYLOR_CAMARO1532
Replaced the batteries, and nothing works. Car can lock and unlock from inside with buttons manually, but i cannot lock my car for safety because i have to unlock it with the key and that sets off the factory alarm every time.
Dec 12, 2021 at 3:08 AM
SQM
  • 6,383 POSTS
It sounds like the fob has lost connection with the central locking module. It can also be due to a faulty module or wiring issue.
First try to program the key to the vehicle and see if that will work.
Follow these steps:
Ignition switch to "run" position, try to start and let key return to "run" position
About ten minutes later security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of three relearns.
Turn key off, then start it.
https://www.2carpros.com/articles/how-to-re-program-a-key-remote-fob
Please let me know if this works.
Dec 12, 2021 at 10:24 AM
