key doesnt work. no power in car
140,000 MILES • 2.0L • 4 CYL • TURBO • RWD • AUTOMATIC
C-S-THOMAS
when i put the key in the ignition, it doesnt turn. it makes No sound.
abs brake light was on for months, a mechanic said it would eventually lock up. is that what happened?
i really want to get this fixed. i am the 2nd owner of this car. I have had it since 2005, i really don't want to junk it.
please help
Dec 10, 2013 at 10:47 AM
  • 75,988 POSTS
Might want to start at the ignition switch cylinder lock-
Dec 10, 2013 at 2:07 PM
C-S-THOMAS
thank you for responding. where do I find that switch? is that something I switch on or replace ignition?
Dec 10, 2013 at 5:15 PM
EXOVCDS
  • 1,882 POSTS
Watch the following videos I made, so you can do some testing:
http://www.youtube.com/watch?v=vEdr2Q0atA8
http://www.youtube.com/watch?v=JJKthmyLffc
The problem in the video is different from what you described, but the videos will show you how to gain access to the ignition switch, so you can use a screwdriver to see if it will crank.
Standard or automatic?
Thomas
Dec 11, 2013 at 7:22 AM
