key and gear shift frozen
97,000 MILES
CJSOMSEL
key and gear shift frozen.
Feb 10, 2018 at 8:35 AM
JIS001
  • 3,412 POSTS
What is the question? How is the key and gearshift frozen? Can you turn the key to the start position and start the car?
Feb 10, 2018 at 4:32 PM
CJSOMSEL
the key is frozen in the ignition and will not start.
Feb 11, 2018 at 4:52 AM
JIS001
  • 3,412 POSTS
Does the key come out? Try rocking the steering wheel back and forth while turning the key. If you have another key, try it to eliminate the problem with the key. But let me know first if the key is stuck in or you just cannot get the key to turn over.
Feb 11, 2018 at 5:09 AM
CJSOMSEL
It did not work. Is it somehow locked?
Feb 11, 2018 at 5:26 AM
JIS001
  • 3,412 POSTS
Is the key out right now or stuck in?
Feb 11, 2018 at 5:41 AM
