Key does not turn
2006 SUZUKI FORENZA
161,116 MILES • 4 CYL • 2WD • AUTOMATIC
SIMONE HALL
My key is in acc and will not go to Lock. What do I do?
May 16, 2018 at 2:27 PM
  • 110,194 POSTS
Hi and thanks for using 2CarPros.com. If it suddenly will not turn to the off position, make sure the shifter is fully in the park position. The system has a park lock set up and will not allow the key to return to off without being fully engaged in park.
Let me know if you have already done this or if you have other questions.
May 17, 2018 at 8:36 PM
